Replace Sill Plate To Basement Block Wall - No Anchor Bolts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 09:48 AM   #1
Smile
House Fly Away - No anchor bolts
Okay, so my house isn't going to fly away, I think. I hope! No j-bolts. Rotted sill. Need to attach new GT sill plate.
Background
Located in WI, zone 6.
The lower half of my basement walls are constructed with 3 core concrete blocks (8"x8"x16") with a solid concrete block (6"x4"x16") cap. See photo. The remainder of my basement height is obtained by a 2'-10" tall 2"x4" pony wall nailed to the concrete cap blocks. This is a 1960's raised ranch. The bottom plate of the pony wall serves as the sill plate. It is not treated lumber.
There is only one floor above.
Problem
The bottom plate of the pony wall has three short sections with rot. I would like to at least replace the rotted sections. The photo shows drywall but most of the wall is bare studs. At some point I would like to enclose the wall and insulate. While cutting out the rot and replacing with short sections of 2"x4" would be quick and easy, I keep thinking that replacing all the sill with green treated 2"x6" prior to enclosing makes the most long term sense.
The existing pony wall sole plate/sill plate is nailed to the concrete cap blocks using concrete nails, no j-bolts. Do I nail the new sill plate? Do I fill cores every 4' or so and add j-bolts?
Possible Approach
One thought I had is to remove the cap block every 4'-6' around the foundation and fill two adjacent cores in each of those areas. And then place a j-bolt in the concrete, resulting in j-bolts every 4'-6' around the perimeter of the foundation wall to attach green treated 2"x6" sill plate. The j-bolts would stick up enough to allow for sliding the j-bolt head through a hole drilled in the cap block. The cap block would be remortered.
I have screw jacks to do any lifting and I can construct temporary 2"x4" walls to support the floor above.
Is this overkill? Could I really just renail a new sill plate directly to the concrete cap block? That doesn't seem sufficient. Do you have another or better way?
Thanks in advance for any recommendations or experiences you can share.
Replace Sill Plate to Basement Block Wall - No anchor bolts-block-wall-close-up-2.jpg
DoItMyselfToo is offline   Reply With Quote
Old 09-10-2011, 11:00 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Drill through the sill and epoxy the fasteners in place if you want to. If your blocks aren't filled now and only anchored to the cap blocks I wouldn't worry about it, if a wind or quake is strong enough to move your house the mortar of the cap blocks sure won't hold it.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-10-2011, 02:55 PM   #3
jiju1943,
Thanks for your response. At this point, I pretty sure that I'll replace the sill plate. I don't want to enclose my wall only to open it later because I took a short cut. I'm in my late 30's and planning to retire here, so this is more long term forward thinking. I want to relax in retirement, so trying to take care of the big stuff now.
Just trying to get a bunch of feedback. More heads=better projects.
Gareth
Old 09-10-2011, 03:01 PM   #4
kwikfishron's Avatar
Rewards Points: 414
Thatís assuming you know which heads to believe.
kwikfishron is online now   Reply With Quote
Old 09-10-2011, 03:07 PM   #5
Oh, yeah...I forgot about that part. Oh well. I was never told this life thing would be easy.
Tags
anchor , concrete block , j bolt , sill plate
How tight is too tight for a new basement wall? vseven Building & Construction 16 01-07-2010 08:50 PM
Building a 1/2 wall in a basement? BowDown Building & Construction 1 07-27-2009 02:13 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-08-2009 11:49 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
