Replace Sash With Casement Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-11-2009, 12:48 PM   #1
replace sash with casement window
i need to change a 30x53" sash type into casement type to meet egress requirement. is it possible to leave in frame, remove sashes and retrofit? if not , how to switch window with minimum damage to interior/exterior trim
fiostech is offline   Reply With Quote
Old 11-11-2009, 02:40 PM   #2
Rewards Points: 6,652
Pictures do wonders in knowing what you are trying to do. Take a wide angle shot from about 6-8 feet away from the window (use extra lighting if room is dark, along with flash). Once posted with pic, better answers can be given.
Old 11-11-2009, 05:08 PM   #3
Rewards Points: 5,336
My vinyl window supplier will make a casement replacement window for a doublehung opening.
Check your local supplier.
Ron
Replace a window with Bay Window? Eusibius2 General DIY Discussions 4 10-09-2009 12:10 PM
Casement window doesn't close all the way jasontal Building & Construction 1 08-23-2009 09:23 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
