-   -   replace sash with casement window (http://www.diychatroom.com/f19/replace-sash-casement-window-57002/)
fiostech 11-11-2009 12:48 PM
i need to change a 30x53" sash type into casement type to meet egress requirement. is it possible to leave in frame, remove sashes and retrofit? if not , how to switch window with minimum damage to interior/exterior trim
gregzoll 11-11-2009 02:40 PM
Pictures do wonders in knowing what you are trying to do. Take a wide angle shot from about 6-8 feet away from the window (use extra lighting if room is dark, along with flash). Once posted with pic, better answers can be given.
Ron6519 11-11-2009 05:08 PM
My vinyl window supplier will make a casement replacement window for a doublehung opening.
Check your local supplier.
Ron
