Old 06-01-2010, 04:24 PM   #1
Replace RIM JOISTS
I have some French doors that have been leaking for sometime, when we took the current doors out and opned the Subfloor up, the rim joists under each side of the door frame was rotten along with about 4 inches of the 2x4 bottom plate. Luckily the sill plate is great and untouched and so is the joists. My Contractor I hired decided not to replace the rim jpoists as he said he couldnt get to it, he formed and poured concrete under each door frame. My new doors are coming I am putting in a Jam sill along with BUTYL flashing to try and prevent this again. MY biggest worry is the rotten Rim joists, Im afraid if water does penetrate it will just run between the concrete and subfloor creating a buckling of the floor also this concrete stops short of the Basement ceiling, I sure dont want it dripping on it. Anyone have any Ideas or seen this done. I have time to get the concrete out and do it myself right Before the door arrives.
MIKE72 is offline   Reply With Quote
Old 06-01-2010, 09:00 PM   #2
Replace RIM JOISTS
If you have access from underneath, perhaps blocking could be sistered against the inside of the rim joist. This would be important under the king and jack studs for the door opening.
Old 06-02-2010, 08:16 AM   #3
Replace RIM JOISTS
Thanks, I have a little acces from underneath, while the sublfloor was out I can get good access to sister in some rim joists. This is what I thought they were going to do. Thats why they pourde concrete to get a good foundation under the king and jack studs. Still I dont know if it was a good idea or not.
how to replacing termite damaged ceiling joists expediter Carpentry 4 08-20-2009 10:58 PM
Connecting Sister Joists tdiantonio Building & Construction 3 07-24-2009 07:34 PM
Is it ok to replace old joists. whoowah Carpentry 6 05-21-2009 05:33 PM
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 8 04-05-2009 10:20 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 09:50 PM
