Old 03-22-2008, 10:31 PM   #1
replace porch post on concrete slab
need suggestions for replacing the porch supports on a concrete deck/porch.
We have rotting cast iron (circa 1950s) holding up the roof of the front porch.
I want to replace it with something simple and less likely to rot.
Wood posts in a bracket that holds the wood off the concrete surface would be fine. To do that I would have to drill into the concrete to secure the brackets but am worried I will crack the concrete as the posts fit right on the edge of the concrete.
I am in south florida. Any suggestions for me?
thanks
maa40 is offline   Reply With Quote
Old 03-23-2008, 08:29 AM   #2
electrical contractor
I drilled one hole in the center at the bottom, inserted a rod, then drilled the porch, slid the rod in the hole with the post over it, and secured it at the top. The rod keeps the bottom from sliding if someone leans on it, and the screws at the top keep the whole post from twisting around the rod. It worked for me.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 03-23-2008, 11:50 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
You may need to use a 2X4 "T" to support the porch roof weight while you're replacing the posts.
I used pressure-treated 4X4s as main post supports on our porch roof. You can get square cast aluminum brackets with four very short little "legs" with a hole in the middle to keep the wood from ocntacting the concrete. Get brand-name pressure-treated wood with a 50-year warranty.
I covered and boxed the 4X4 posts with cypress boards to match our house siding. You can cover wood with anything that can be screwed or nailed to it of course.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
My name is Gail Thompson, owner and operator of Gardens to Grow in Pacific Grove, California. We are here today to instruct you on how to install a picket fence. Of course you will need some concrete mix. Now this is a ready to use concrete mix that you... Read More »
Now we are going to show you how you can attach a new picket fence to a pre-existing picket fence. Now what we have done here is we have taken this pressure treated 2x4 and we have simply nailed it to a pre-existing 2x4 foot pressure treated frame. Now... Read More »
This is my pressure treated 2x4 used for the framing of your picket fence. Now on this picket fence the frame, the bottom, and the top are pressure treated 2x4's. Now since this is a 24 foot long fence we will need 6 - 8 foot 2x4's. Now when you measure... Read More »
Victorian architecture became popular during the reign of England's Queen Victoria in the late 1800s to the early 1900s, but the period of Victorian architecture spans from 1825 to 1900. The most popular of these houses was the Queen Anne. Queen Anne... Read More »
Prior to putting in our 4x4 posts for our picket fence I put in about 4 or 5 inches of water at the bottom of the hole. I then will take about 1/3 of our first sack of our ready to mix concrete. I will pour just enough in there so that we can start... Read More »
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
replace porch post? lrciii Building & Construction 3 07-16-2007 10:12 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
