Replace Porch Post? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2007, 05:17 PM   #1
replace porch post?
Greetings,
I need to replace the post that holds up one corner of the roof over our patio. Original moron just set it in the dirt, no idea how far it goes down, but its rotting & needs replacing.
Obviously I will pour a proper foundation for this post. Living in Florida, what is the best way to attach the new post to the concrete & at least get close to hurricane codes.
Thanks!
Lee
lrciii is offline   Reply With Quote
Old 07-12-2007, 07:32 PM   #2
Not sure about Florida. Up here in Washington state I would dig a hole 2 feet deep with a diameter of 30", put a 30" tube in the hole, put post in and fill with concrete.
warnerww is offline   Reply With Quote
Old 07-12-2007, 07:51 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by lrciii View Post
Greetings,
Thanks!
Lee
Go here: http://www.strongtie.com/hw/index.html?source=hpnav
If you have trouble finding what you think you need, contact them (Simpson Strong Ties) directly.
Link: http://www.strongtie.com/Contact_Us.asp
Or call (800) 999-5099
- Build Well -
Old 07-16-2007, 09:12 AM   #4
Rewards Points: 5,336
Why don't you just go down or call the Building Dept. for an informed opinion as to what you need. It's the hurricane issue that is the question.
In lower NY I would sink a 12" sonotube down 40" and fill it with concrete and anchor in a Simpson post hardware. I'd mount the post on the hardware and not in the concrete.
Better to do it once correctly.
Ron
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 11:41 AM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 09:33 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 04:20 PM
