Replace Lock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 05:10 AM   #1
replace lock
how to replace garage door lock? Is it a two man job?
atileo is offline   Reply With Quote
Old 12-31-2011, 07:22 AM   #2
That depends on how handy you are. I have worked alone for 27 years, with occasional help for large or heavy items. Assuming you are talking about the lock mechanism that runs to the sides of the door. I would have no trouble replacing a garage door lock by myself. But why does it need to be replaced. Often the lock mechanism it self needs replacing due to lost keys or just worn out latch, etc. The bars rarely need to be replaced.
Old 12-31-2011, 11:08 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
atileo,
You could save everyone a lot of time if you would simply tell us what lock where. Is this on an overhead door? Is this on a walk-thru door? What?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (12-31-2011)
Old 12-31-2011, 12:11 PM   #4
Rewards Points: 6,652
Depends on if you need someone to hold your beer and grab tools for you.
Porcelain click and lock floor tile TRACKER Flooring 16 07-17-2012 07:59 AM
Do I replace Heat Exchanger or wait? coder_t2 HVAC 17 12-18-2011 02:33 PM
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 07:37 AM
Should I replace all of the plumbing? Pics enclosed? twilightcall Plumbing 15 01-23-2008 09:50 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
