Replace Or Keep Baseboard Moldings When Replacing Doors? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2008, 05:18 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
Replace or keep baseboard moldings when replacing doors?
Quick question, I am getting to replace three bedroom doors with some prehung doors from the bigbox store. On one of the walls in two of the bedrooms, there is a long baseboard section - 16'er or close to it. Is it worth trying to pry back this molding and save it, or just remove/replace it. Or would it be worth cutting it back and replacing whatever small section I can with a scarf joint.
J187 is offline   Reply With Quote
Old 09-09-2008, 05:46 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
That is entirely up to you, if it is in your own home.
Tho, this is the way I would look at it:
Right way(Doing it on a professional job): Removal of the length of board to the next joint, or wall.... & replace it.
Saving money on your own home: You can pry it out and do a scarf joint. If it is paint grade, you can also patch the area, and sand it, to make it blend, before final painting.
- Build Well -
Old 09-10-2008, 12:44 AM   #3
Nia
Ditto
Why cut corners with your own house? You took the words right outta my mouth.
Nia is offline   Reply With Quote
Old 09-15-2008, 02:36 PM   #4
J187's Avatar
Rewards Points: 506
I have no problem replacing it. The molding was cheap enough. Thanks
how to install sliding glass doors but baseboard heat reg. is in the way chas2jones HVAC 1 08-11-2008 06:31 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
Replacing hollow doors with 6 panel eehammar Remodeling 2 02-16-2008 02:27 PM
Replacing hydronic baseboard mountainview HVAC 6 11-23-2006 04:38 AM
Replacing Doors artie Carpentry 2 03-06-2006 10:21 PM
