Replace or keep baseboard moldings when replacing doors?
Quick question, I am getting to replace three bedroom doors with some prehung doors from the bigbox store. On one of the walls in two of the bedrooms, there is a long baseboard section - 16'er or close to it. Is it worth trying to pry back this molding and save it, or just remove/replace it. Or would it be worth cutting it back and replacing whatever small section I can with a scarf joint.
That is entirely up to you, if it is in your own home.
Tho, this is the way I would look at it: Right way(Doing it on a professional job): Removal of the length of board to the next joint, or wall.... & replace it. Saving money on your own home: You can pry it out and do a scarf joint. If it is paint grade, you can also patch the area, and sand it, to make it blend, before final painting. |
Ditto:thumbsup: Why cut corners with your own house? You took the words right outta my mouth. |
I have no problem replacing it. The molding was cheap enough. Thanks
| All times are GMT -4. The time now is 03:13 AM. |
