Replace Hand Ued Support Beam With A Laminate Support Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-24-2012, 08:01 AM   #1
replace hand ued support beam with a laminate support beam
I am restoring a 1930 cape style house built on a sand floor with a cynder block four foot crawl space. One of the original support beams that was probably from an old barn is starting to show some dry rot. I want to replace or supplement this beam. I thought it would be least expensive to simply add a laminate beam next to the old beam and dig footings and add steel lally columns to to sprrort the new beam. This would eliminate the cost of removing the old beam and also keep the original support in place. Doesthis sound like the correct approach?
bwx1182 is offline   Reply With Quote
Old 10-24-2012, 12:59 PM   #2
GBrackins's Avatar
Rewards Points: 2,092
are your floor joists lapped over the existing center beam? if so, your new beam needs to be under the lap so that it supports the joists .....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
want lowest profile load-bearing support beam (removing wall) rpk7309 Building & Construction 2 05-17-2012 07:48 AM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 01:51 PM
My basement support beam rmugford Building & Construction 6 03-11-2010 09:24 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 10:14 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
