Replace Garage Door Springs In Pairs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 07:49 PM   #1
Rewards Points: 682
replace garage door springs in pairs?
I have a garage door with 4 side mounted springs. One is broke. Should I replace just one pair? Or do I need to replace all 4?
darsunt is offline   Reply With Quote
Old 05-18-2011, 09:11 PM   #2
Rewards Points: 252
I would replace all of them at the same time. If one has broken, the others have had the same amount of wear. Also, newer springs tend to be tighter and pull at different rates.
If you don't have them now, install the safety wire as well. If your spring explodes, it will keep the pieces from flying all over the place.
Marty1Mc is offline   Reply With Quote
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 09:03 PM
How To Replace an Old Garage door Lock system apetrag How To Guides 4 12-17-2009 06:31 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
