-   -   Replace Bathtub w/ Shower Only (http://www.diychatroom.com/f19/replace-bathtub-w-shower-only-2958/)
mahjohn 07-05-2006 09:38 AM
I have seen some remodelling done where the standard bathtub with tile surround was ripped out and replaced with just one big 60" shower. The questions I have may be stupid...but then again maybe not. After I pull out the tub, via sawzall or whatever means, i'm assuming I would then rough use 3/4 plywood, with 1/2" concrete board ontop of that ? This would give me the floor of the shower..(would need to slope to drain), but then how would I build the lip/side/step (right terminology escapes me) the you step over to get into the shower..simple framing with concrete board to handle the tile ? For the sides I would simple ripout the old tile and replace with concrete board/new tile.
J187 07-05-2006 03:07 PM
Just out of curiousity, have you considered a nice fiberglass shower unit? Like one of these...
http://www.lascobathware.com/browse....-DTS&series=13.
Big Dave 07-05-2006 03:41 PM
For the lip just frame a short wall to whatever height you want then backerboard and tile. The most important step is to put a shower pan in and install the tile over that. Back in the old days they used lead. The last one that I seen put in was a rubber membrane then they poured a concrete over that (can't remember what it was called ) and sloped it to the drain and installed tile on that. This is not a typical DIY type of project. Alot of things that can go wrong if your not sure of what you are doing.
Dave.
Darylh 07-06-2006 09:11 AM
Here is a system I am about to use.Check it out http://www.schluter.com/english/prod...omponents.html
I am not affileated with them.( cant spell either lol)
