Replace Basement Entry Door With Bulkhead - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 08:57 PM   #1
Replace basement entry door with bulkhead
My basement entry is a standard 80 inch door. The basement floor is 48 inches below grade. Can I use a bulkhead door for entry instead? How do I get the headroom needed?
gleasonav is offline   Reply With Quote
Old 09-11-2012, 09:02 PM   #2
Rewards Points: 12,808
Posting a picture would sure help figure out how to do it.
Old 09-11-2012, 09:18 PM   #3
Thanks- will do
Old 09-11-2012, 09:29 PM   #4
Rewards Points: 3,346
Are you saying you want to remove your existing door and use a bulkhead door instead???
Canarywood1 is offline   Reply With Quote
Old 09-12-2012, 05:03 AM   #5
Something like this you mean?
http://www.newenglandbulkhead.com/images/1b.jpg
Need to see a photo of the entryway, not sure I understand how your basement floor is only 48 inches below grade, unless you are on a slope or something and your 1st floor is 7ish feet above grade?
weekendwarrior9 is offline   Reply With Quote
Old 09-12-2012, 09:59 AM   #6
I want to cover the 4' well somehow with a bulkhead sealing it.
Snow and debris collect in it. Thanks
Old 09-12-2012, 10:04 AM   #7
The house was called a 'split entry' with the basement floor 4' below grade and the first floor 4' above grade. Thanks
Old 09-12-2012, 11:25 AM   #8
GBrackins's Avatar
Rewards Points: 2,108
I cannot see if there is a window in the wall above the basement door. can you build walls with a roof over it and install a door to the exterior? would allow you to have a walk-in entrance and keep the weather out.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
gleasonav (09-12-2012)
Old 09-12-2012, 12:54 PM   #9
Yes- the well collects snow and debris. Thanks
Old 09-12-2012, 02:23 PM   #10
Hmmm... Don't see a reason that you couldn't put in bulkhead doors iof you really wanted to, but they are going to be at a steeper angle than must are installed at, and you are right the head clearance is going to be kinda tricky since you have the overhang from the 1st floor.
Call out a storm door company that'll give you a free or cheap estimate and pick their brains about similar installs and ask what others have done. Ask for photos, can't hurt.
GBrackins probably has the right of it, you might want to just build an overhang entry of some sort instead. Might mess with your clearances and look for that staircase though
The Following User Says Thank You to weekendwarrior9 For This Useful Post:
Old 09-12-2012, 05:30 PM   #11
Thanks-
Basement moisture/humidity issues amason2308 Remodeling 2 09-12-2012 09:27 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
entry door repairs or replace? mudpaws Carpentry 8 06-08-2009 10:13 AM
Cost to replace entry and screen doors?? kiss44 Carpentry 6 01-30-2009 10:46 AM
basement entry tmac General DIY Discussions 3 10-25-2005 12:29 PM
