Replace Aluminum Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-27-2008, 01:31 PM   #1
I live in Vancouver and I am am wanting to replace the old aluminum windows. I am trying to decide to go with new contruction windows or replacement windows. As I understand it: New contruction windows cut back siding to access framing to attach nailing fin and this would probably also redoing trim etc inside. Replacement windows I would have to cut out existing window frame and then slide in new window with no modifications inside. What will the quality of the seal be considering the profile of the siding? Any input would be appreciated. Pics attached.
lpcon is offline   Reply With Quote
Old 09-27-2008, 01:42 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I would go with a new construction window. size up your window and see what comes close to the opening you have now. you might have to close in an 1" or 2" or it might just fit. either way you will need to install some type of trim around of the outside of the window. pry away the siding just enough to install the proper flashing behind and over the flange for a water tight seal. I'm not a fan on replacement windows unless they are installed in a existing window frame. Just my pet peeve. BOB
Old 09-28-2008, 07:48 PM   #3
Thanks for the feedback
Old 12-09-2011, 02:52 PM   #4
Hey Ipcon,
Did your replacment windows make a difference in your house?
dbc12 is offline   Reply With Quote
Old 12-21-2013, 12:28 PM   #5
block frame sliding window install
Our contractor installed Milgard vinly block frame sliding windows in our home. He cut out the aluminum sliding window and left the nailing fins under the siding. Installed the block frame sliding windows and put screws through the jams of the block frame sliding window that are screwed into the sheathing and not into the wood jam of the frame. Is that a correct install?
station1111 is offline   Reply With Quote
Old 12-21-2013, 02:59 PM   #6
Rewards Points: 13,456
station1111 please go back and add your own post, not add onto someone else's.
Impossible to keep track of the reply's.
Old 12-21-2013, 03:01 PM   #7
You can not use replacement windows with that style window. Going to have to go with new construction.
What type siding is that?
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
Replace Aluminum Windows yellowsky7 Building & Construction 5 09-10-2008 07:03 PM
Replacment Seals Aluminum Windows 290 General DIY Discussions 1 10-24-2007 03:29 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
