Replace Air Compressor Motor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 09:51 PM   #1
Replace air compressor motor
I have a sears 919-16560 air compressor and I can't get the old motor shaft out of the front bearing,is it pressed in. any ideas?Bill
Hoverwas is offline   Reply With Quote
Old 02-13-2011, 10:15 PM   #2
Rewards Points: 5,336
Use a puller to remove the bearing from the shaft. Use a press to put the new bearing back on.
Ron
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
Is it time to replace the toilet? Deahmx Plumbing 8 08-12-2008 02:11 PM
