Old 10-24-2010, 07:39 PM   #1
Repairing wood rot at base of beach house 10" x 10" posts
I'm considering buying a 30 yr. old beach house, and had my inspection yesterday. The house sits up on 20 10" x 10" treated wood posts. Several of the exterior posts are rotting, to the point I could put half my hand into one at ground level.
The advice I've received so far is either to
a) 'sister' a new post to the outside of each exterior post, digging 8ft. down and extending up to the base of the house then bolting to the existing posts OR
b) dig out the rotten wood and fill with epoxy
Frankly, I'm considering both. I'm also considering bracing all 14 exterior posts, not just the 4-6 I've found problems with.
Am I going to far? Should I walk away from this deal?
Thanks!
Mike
mikebeahn is offline   Reply With Quote
Old 10-25-2010, 12:57 AM   #2
Moderator
Treated wood will rot unless waterproofed. You need to find the water source..... sistering may not be acceptable with the local Building Department. Epoxy will not work structurally. Hire a Structural Engineer and a soil expert for advice, then a house mover to crib the house while making repairs, then a General Contractor with expertise in piling replacement, after asking the B.D. about similar local cures. You may need new sub-grade footings to meet today's Codes. Possibly steel for the nearby water saturation....
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Tags
beach, posts, rot, wood
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
How to replace wood support posts under main beam webjanet Building & Construction 1 09-07-2008 11:15 PM
Add-on wood furnace in a small house? Jim Dam HVAC 1 06-24-2008 02:48 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Repairing the wood for painting bofusmosby Painting 4 06-17-2007 12:55 AM
