Repairing Support Beams On Beach House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 08:45 AM   #1
js1
repairing support beams on beach house
I have a beach house supported by 8"x8"x12' high marine grade wooden beams (stilts, piers). The harsh environment, and age has caused some rot that has deteriorated down to ~3x3 at the base where it touches the concrete slab on about 7 of the total of 40 supports. They look to have been placed into the ground ~2-3 ft and then concrete poured around them and then a concrete slab was poured. I know I could cut out a 3x3x3 area and replace the beam, foundaton, etc. but I really dont want to do that unless I have too. It would not hurt to raise the floor so I thought about just leaving them and pouring a new 7" rebar reinforced pad and attaching with A24 simpson strong tie L brackets and anchors. I have also seen where people jack up the house, support it temporarily and then cut off the post and just pour a small concrete base/plinth. However in my case the post go 2-3 feet into the ground and after I cut them off the old portion is still going to be in the ground so I am not sure how to disperse the load away from the rotten post left in the ground? Also thought if I placed another support metal or wood beside it. Suggestions PLEASE.
js1 is offline   Reply With Quote
Old 04-09-2011, 10:05 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
My suggestion is to get real professionals involved in this as this is not anywhere near a DIY project.
Andy.
AndyGump is offline   Reply With Quote
Old 04-09-2011, 12:03 PM   #3
Send a message via MSN to reality
I have to go along with Andy on this. I have built many homes like yours and your post go down more than 2 or 3 feet they are pounded in. They start out just like a telephone pole and are driven down. Call a pro for this.
reality is offline   Reply With Quote
Old 04-09-2011, 12:27 PM   #4
Experienced
Jackofall1's Avatar
Hello and welocm Js1, to the best darn DIY'r site on the web.
I have to go with the earlier responses, at least to have a proffessional over to make recommendations, after which you may not want to touch the job yourself.
Sure would be nice to see some pics, I think this is a real interesting one.
Mark
roof support beams dwhelton Building & Construction 1 10-16-2010 12:08 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Need advice on support beams in older house Vlmrdm Building & Construction 1 05-03-2010 12:26 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 07:32 PM
