Repairing Sump Pit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 08:41 AM   #1
Repairing Sump Pit
Our house is 12 years old. The basement has 2 sump pits. One is a normal sump pit to remove groundwater and one is for a bathroom...a sewage ejector pump.
The problem I have is with this sewage pit. I don't have a bathroom in my basement, and do not plan on it, however this pump has been running. Upon investigation, the problem is where the 3" or 4" PVC drain (from what would be a toilet) comes through the side of the pit (under the basement floor). I don't know how these are installed but it appears that there may be a gasket that goes around the PVC on the outside of the pit. The groundwater is getting between the PVC and this gasket and seeping into the pit. There are 4 bolts on the inside of the pit, which I assume hold the gasket...I have tried tightening those. The pump runs about every 10 mins in the spring or when we have saturated ground due to rain.
The reason I am worried about it is because it is now another sump pump that I have to watch and make sure it doesn't quit (basement is finished) Or when power goes out I don't have a battery backup on it. The pump is as old as the house.
Has anyone had this problem or does anyone know if there is a way to fix it? I would like to fix it so I don't have to worry about the pump running...or not running!
Chris
cbridges is offline   Reply With Quote
Old 03-06-2011, 08:51 AM   #2
Rewards Points: 4,752
here's the real problem - this sump's connected to the sanitary system & ( in most jurisdictions ) its illegal to pump anything BUT sewage,,, replace the discharge line so it pumps legally ( to the top of the ground OR a leader drain ) & forget trying to stop the leaking water
battery backups are approx $250 incl marine storage battery & charger,,, we like water powered backups ( $400 ) as its more common for elec to fail during storm rather than municipal wtr supply.
Old 03-06-2011, 04:01 PM   #3
That may be what I do instead of trying to fix the leak. I do need to get it from pumping in the sanitary sewer as it is illegal here as well!
sump pit/pump questions aliasoink Building & Construction 8 03-02-2010 11:41 PM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 06:28 AM
Why is My Sump Dry? kwilliam10 Plumbing 2 05-03-2009 07:49 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 09:48 PM
