Repairing Stucco On A Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 04:43 PM   #1
Repairing stucco on a block wall
My block wall, finished with stucco has damage from years of sprinklers hitting it. Now there are several areas that have crumbling stucco. I used a trowel to scrap off the brittle areas and need to patch them. I went to HD and asked how to do it and want to run his answer by those who are in the trade and actual experience. So here's what he said in detail.
Materials - mortar mix (1 hr), color coat, green float. He said the process goes like this: mix the mortar mix, wet the wall area, trowel on the morter and let set until fairly firm, trowel on the base color coat. Wait 15 minutes and use the green float to smooth around the edges (for a good transition), then trowel on the 2nd color coat (texture coat) and match to the existing texture.
If anyone has thier own two cents (agreeing to what I was told or otherwise) I would appreciate it. Thanks.
kevinf. is offline   Reply With Quote
Old 08-29-2011, 02:13 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 806
Really need to see of pic....
But I have used a 'stucco in a bucket' product from HD...comes in a 1 gallon bucket and is intended for stucco repairs....It's worked well for me...
ddawg16 is online now   Reply With Quote
Stucco vs cinder block wall( cost) fta123 Building & Construction 2 04-20-2011 11:14 AM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
2.5 to 3 ft ht standard block wall cprao Building & Construction 5 07-31-2010 12:11 PM
Mortar bed removal from block wall Douger_F Building & Construction 8 04-15-2009 08:47 AM
Removing a (block) wall - questions Genhawk21 Building & Construction 3 09-08-2007 07:26 PM
