Repairing Small Concrete Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-15-2010, 12:14 PM   #1
Rewards Points: 1,010
Repairing small concrete patio
I removed a shed from my backyard a year or so ago, and left the slab in place. It's cracked and not level. What I'd like to do is pour in just enough concrete to fill the cracks and level it out. It doesn't need to be perfect, as I'm just going to put some benches and a fire pit there.
I live in southwest Ohio. Any tips or suggestions? Obviously I need to put a wood frame around the existing slab to mold the new concrete, pour, and then remove it when dry. But other than that, any tips or suggestions on type of concrete, ways to make sure it fills all the gaps, etc?
spaceman spif is offline   Reply With Quote
Old 09-15-2010, 10:59 PM   #2
34 views...no replies. What's the record???
Old 09-16-2010, 03:42 AM   #3
Rewards Points: 4,654
' just enough concrete to fill the cracks and level it out. ' won't work UNLESS you don't mind the crk reflecting up thru your new work,,, more than likely, that crk is now a joint ( meaning your slab ' moves ' ),,, solids react to tem changes just as do liquids - hi-skoul fiziks
that having been said, your best bet's probably to just repair ( seal ) the crk, place the benches, & have everyone lean to the high side
stadry is online now   Reply With Quote
Old 09-16-2010, 05:51 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... I'd plan on a 4" lift,... In other words, a New slab on top of that 1...
Use steel for reinforcing,+ a layer of sand to isolate the under slab's movements...
Bondo is online now   Reply With Quote
Old 09-16-2010, 09:18 AM   #5
Another 4"? Hmmm...that would look awkward. The existing slab is already about 3" above the ground, so another 4" would create a patio that's 7" tall, and that might look odd sticking up that high out of the ground. And tearing up the existing slab and repouring it is more work than it's worth!
Old 09-16-2010, 10:52 AM   #6
Rewards Points: 558
Drill into existing concrete slab to except 10mm re-bar and use epoxy to set them in place. Then build a form and pour your new concrete.
epson is offline   Reply With Quote
Old 09-16-2010, 11:53 AM   #7
Not a bad idea. Any suggestions on how far apart to space the rebar?
Old 09-17-2010, 08:14 AM   #8
Rewards Points: 558
Space them apart every 6
Concrete Patio Remodel brm6685 Landscaping & Lawn Care 4 10-27-2010 07:51 AM
Concrete Patio too close to siding??? ddave23 Landscaping & Lawn Care 2 07-26-2010 06:51 AM
Flagstone over concrete patio mikereno1 Landscaping & Lawn Care 2 04-29-2010 06:50 PM
laying small stones in mortar on a patio Gary Schenk Building & Construction 1 09-21-2009 09:27 AM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 01:30 PM
