Repairing Masonite Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 07:46 PM   #1
I have masonite siding laid out vertically in 4x8 sheets, two levels. There are some gaps were they butt together. Also there is some fraying at bottom of masonite. I've used the Previously installed nails to indicate were the stud location would be, and used some 2" screws to resecure the butt joints and caulked the gap. My screws however do not seem to be biting into anything firm. Do I need to consider pipes or electical in the wall? Also what can I do about the swelling and fraying of masonite at the bottom?
Brettjones is offline   Reply With Quote
Old 09-18-2011, 07:55 PM   #2
kwikfishron's Avatar
Rewards Points: 86
Welcome to the forum Brett
Yes you should.
There is not much you can do but replace the damaged siding.
kwikfishron is online now   Reply With Quote
Old 09-18-2011, 07:56 PM   #3
DIY staff
Rewards Points: 7,174
Replacement is the best option----Trying to patch the swollen material is a one year fix----
Kind of like slapping Bondo on a rusted jalopy.
Sorry to bear bad news----Mike---
Old 09-18-2011, 08:10 PM   #4
Repair fraying masonite
Are the pipes and electrical generally laid after the 2x4 stud (towards the inside of house). If Im using a 2" screw is there any chance to hit a pipe or wire if in fact the other nails are missing a stud? Will a Stud finder read a stud through masonite siding?
I think the masonite isn't overall in the worst condition I just want to seal
the gaps and repair the bottom which is starting to fray to get as much
life as I can out of it.
Old 09-18-2011, 09:01 PM   #5
Rewards Points: 86
You should be able to see the existing nails on sheet siding. That’s were the studs are.
Post a picture or two. How to attach a photo to a post
Old 09-19-2011, 04:08 AM   #6
Rewards Points: 502
could the studs you are trying to screw into just be that rotten because the siding wasn't up to its job?
forresth is offline   Reply With Quote
Old 09-19-2011, 09:44 AM   #7
Masonite siding
Yes it is quite possible that the 2x4's are rotted. I'll take some pictures of the outside and post them up to get some opinions on how much longer I should leave the masonite on. I just don't want to get rot inside the walls. I can tell the siding is starting to absorb water in a few spots when I push on it.
Thanks very much for all the feedback so far. Just trying to figure out all my options right now. I didnt anticipate the expense of replacing the siding.
Its sounding like I should not waste my time sealing the cracks and repairing the bottom where its frayed. Either live with it, or replace the siding.
Masonite Siding Repair kennykenny Carpentry 6 04-07-2011 08:48 PM
Masonite Siding Repair kennykenny Building & Construction 0 04-03-2011 08:29 PM
Masonite Siding Replacement kennykenny Remodeling 2 07-20-2010 05:52 PM
Hardie over Masonite siding??? canyonbc Remodeling 2 01-27-2010 09:57 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
