Repairing Loose Newell Post?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 02:39 PM   #1
Question
Repairing loose newell post??
The newell post at the top of my staircase has become loose (I suspect from people swinging around it coming downstairs over the years). I can't get at it from below due to the stairs construction. It is oak, as are the stairs, banisters, ballusters, etc. Any suggestions on how to repair it and tighten it back up. I suspect when it was built there was a lag bolt(s) installed up from the bottom.
Rod
Rod53 is offline   Reply With Quote
Old 09-07-2009, 02:51 PM   #2
Rewards Points: 5,336
Many times these newel posts extend below the flooring and are bolted to the framing. If you look at the post, does it look like it's on top on the flooring or is the flooring butted up to the post?
If it's on top, you might try pocket screws and plugs, but the better way would be to manage to get to the attachment under the floor.
Ron
Old 09-07-2009, 05:17 PM   #3
Registered User
Rewards Points: 526
It may have one of these: http://www.ljsmithcompany.info/pdfs/...s_Hardware.pdf
Be safe, G
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 02:20 PM
