Repairing Holes In Osb Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 10:49 PM   #1
repairing holes in osb roof
building a house and people putting on decking busted holes in the roof to put their air hose through it (unbelievable) contractor did not catch until felt and shingles applied. he put construction adhesive from underneath and nailed a 2x6 between ceiling joist to cover hole and try to keep adhesive in. should I let him get away with this? house under construction. Approximately 5 holes.
Piksnna is offline   Reply With Quote
Old 12-31-2012, 10:13 AM   #2
Rewards Points: 518
It does not sound like structural issue or even safety, since average foot will span the damage.
This is, in my opinion, a question of your tolerance and what you think of your contractor. I would put the repair in creative repair with repair emphasized. However, it is something that you can insist on proper repair.
carpdad is offline   Reply With Quote
Old 12-31-2012, 11:42 AM   #3
Rewards Points: 2,210
For us we would cut a patch the size and thickness of the hole, put some 2x4 on the flat under it and put the patch in the hole, sounds similar to what he did.
Mind you we would never have made the holes for an air hose.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
woodworkbykirk (12-31-2012)
Old 12-31-2012, 03:42 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
im with mae ling.. if the contractor was too lazy to reroute the hose.. if they were on my site. .it would be the last
woodworkbykirk is offline   Reply With Quote
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 04:18 PM
fixing knot holes in roof decking Steve Burke Roofing/Siding 8 07-03-2012 11:23 PM
cutting vent holes in roof rgee Roofing/Siding 1 09-22-2010 07:02 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
EPDM Roof Repairing Protrusion Leak Basic_Homeowner Roofing/Siding 3 06-06-2007 05:45 PM
