Repairing Front Entrance - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 09:29 AM   #1
Repairing front entrance
These houses were built in 1960
All the houses of this design suffer the same fault to a greater or lesser degree. The photos show the very worst case.
The iron pole goes through the step & rests on a cinder block wall that appears to be a continuation of the foundation.The pole extends to the roof, but I dont think it a support.
The close up picture( sorry about the quality) shows the crumbling block & the rusting metal plate.
My personal thought is that water has penetrated the outside wall, got into the foundation blocks, frozen & thawed in our extreme climate, & over time cracked up the blocks.
The concrete steps seem to be self supporting.
The condition of my own house is far better than the one shown, but has cracks in the parging, & indications of loose cement in between blocks.
I'm thinking along these lines.
Remove the iron pole.Cutting it off at step level.
Drilling a 4 inch hole through the wall , on a line with the block foundation wall & then push as much concrete in as I possibly can.
Finishing off by re-parging the out side wall.
When this stage is complete, I would like to know your thoughts on this idea?
For me to replace the iron pole with a square metal column.Resting on the lower step
Morter in cinder blocks to raise the out-side edge of the steps, even along the top. & then install a patio door-like, glass frame,as a shield from winter snow that always blankets the entrance.
Thank you in advance, for your ideas & criticism.
Repairing front entrance-dsc00084.jpg   Repairing front entrance-dsc00083.jpg   Repairing front entrance-dsc00082.jpg
jankencanada is offline   Reply With Quote
Old 07-24-2010, 01:10 PM   #2
Pro
Nostco's Avatar
Remove/dispose existing, go all new using better construction method w/o hollow cinders
Nostco is offline   Reply With Quote
Old 07-26-2010, 04:12 PM   #3
Can any knowledgeable D.I.Yourselfer give me advice on this? Thank you
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 12:40 PM
Ceramic or Porcelain for Front Room/Living room (advice needed) irishgem@ymail. Flooring 4 07-08-2009 01:46 PM
repairing (front door) jam settinhooks Carpentry 4 04-29-2009 09:47 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
