Repairing Floor Joist Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 07:50 AM   #1
Repairing floor joist problem
I gutted a room in my 100 year old brick row house. The room is 18x15. I also removed an old narrow staircase that had been covered up for decades. The staircase ran to the 2nd floor along the left-hand side of the house. The stairs ran between the brick wall (left side) and a non-structural wall of 1 x 4 pine.
I removed the stairs and the 1 by 4 wall, then brought down the lath and plaster ceiling. The joists run the 15' width and are buried into the brick on both sides. Where the staircase was, the floor joists are attached to a 10' long beam made of two 2x10s ( marked as L below). All the beams are cut so that they lock together, though they did use nails to secure them as well.
My problem is that the previous owner ran ductwork vertically up through the old staircase, and then horizontally through the beam - and right in the middle of the beam. There is a 4x10" hole in this beam has really weakened it and there is a noticeable sag in the floor. I used a floor jack to secure it temporarily.
I need to find a way to fix the beam, and to cover the old staircase. I could remove the beam, replace with two new 2x10s and attach them, and the floor joists using joists hangers. Then create two more beams for where the staircase was, and run joists between them. I could attach one side right into the brick wall on the left.
I am not sure if the floor joists and hangers will support the floor. The room above is a living room should I have a small party.... I would want the floor to come crashing down!!
Any ideas would be appreciated.
I apologize ahead for the lousy visual below!
Brick floor brick wall
wall joists
II--------------------------------------------II
II========================II <- double joist 2x10
II LL---------------------II 18
II steps LL---------------------II
II were LL---------------------II feet
II here duct -> LL---------------------II
II LL---------------------II long
15 foot wide
Bluto123 is offline   Reply With Quote
Old 12-31-2012, 08:36 AM   #2
Rewards Points: 6,652
Really need a picture of the problem.
Old 12-31-2012, 11:13 AM   #3
Rewards Points: 502
Lots of photos are always good, but that depends on assuming you know the points that need to be shown. You are trying to modernize the construction that is century old and hacked at least once. For one thing, you may be required to at least have moisture separation between the wood and the brick support pockets because of the extent of the renovation. Grandfathering ended in your case.
It may look like returning good wood to its places will be thing to do for that ceiling, but, again, for one thing, what are you doing to the floor above? Party...larger space...more live load? I think this needs an structure engineer's opinion on site.
carpdad is offline   Reply With Quote
AFI Problem (Very interesting) Hikyuuri Electrical 9 12-27-2012 08:48 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
