Old 12-17-2009, 10:01 AM   #1
Repairing exterior of carriage house
The garage / carriage house on the back of my lot is in a miserable state of disrepair and I'd like to start planning out how to repair it. The long range plan is a total gut / remodel to make the upper level a small studio apartment so any repairs now will hopefully be simple and cheap - basically a big band-aid. However I do want them to be of some quality, siding over already rotten wood doesn't accomplish much imo...
Structure is 2x4 with multiple layers of siding materials installed. My gut reaction to it is to totally strip off what is there and replace it with OSB, a paint on water barrier and some variety of siding but I'm worried that might be overkill given that I want to totally rework it in a few years. What other options could I investigate without spending a fortune on it? The work will probably happen in the spring as the temperature seems to be parked below freezing for the next month or two.
cellophane is offline   Reply With Quote
Old 12-17-2009, 07:01 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... It makes more sense to me to have a Plan,+ do it Once, rather than any Band-aids...
Do your rebuild/ remodel in stages, as you can afford it,...
This could just be stage 1....
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
