Repairing Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2006, 10:37 PM   #1
Repairing drywall
How do you repair a crack on painted drywall that has occurred on a seam with fiberglass tape? Also what causes drywall to crack like that?
dm62 is offline   Reply With Quote
Old 08-08-2006, 08:31 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Easy repair.
Cause: Most likely a sheetrock seam that hasn't been screwed tightly, or simple house settling.
Repair: Put some 1 1/4" drywall screws into the area, to re-attach the sheetrock tightly to the stud (if that is the cause). You could also use a 'stud-finder' to locate the stud location.
Coat crack with mesh or paper tape. If using paper tape, make sure that you get plenty of compound under it to leave NO dry spots.
Re-coat smooth, let dry, sand lightly.
Repeat the last process............
.... until it is well coated and you can no longer see the tape outline. Each coat should be a little wider and smoother.
The best compound to use is the quick dry, that you mix up yourself....and yes, you can compound over a painted wall. The only issue you run into is: Whatever kind of compound you use takes alot longer to dry over the paint.
Good luck!
- Build Well -
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
windows jamb sticks out past drywall tk3 Remodeling 2 11-28-2006 07:12 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
