Repairing Cracked Concrete Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 11:11 PM   #1
Rewards Points: 87
Repairing cracked concrete walls
I have a wall in the basement thats cracked, and lets in water during heavy rains. I see all sorts of products on the market for waterproof patching, everything from concrete patch, to crystalization products to resins and an assortment of goops and putties. Just wondering, through other peoples experience, what is a good (or not so good) product.
phantasm72 is offline   Reply With Quote
Old 07-09-2011, 06:30 AM   #2
If the crack is ever dry, something as simple as urethane caulk might work. But most caulks require the field to be dry. You need to fill the crack with something that never fully hardens, that will breath with the crack.
Old 07-09-2011, 07:05 AM   #3
Rewards Points: 5,336
If you've done the exterior, "keep the water away" regimen. grading, leaders and gutters, etc., you can try hydraulic cement on the interior or you can expose the foundation outside and apply a water proofing system.
The exterior job will cost more and last longer. I've done interior hydraulic cement and they last for 7-8 years.
Ron
B. Franklin 1759
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 12:24 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 01:01 PM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 03:07 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
