Old 09-12-2009, 09:12 PM   #1
Repairing Concrete Steps
I just moved into a new apartment not realizing the back steps were in such disrepair. My knowledge of home repair is limited and I'm on a budget. I'd really appreciate some advice on repairing these steps and then painting them.
deadwalk85 is offline   Reply With Quote
Old 09-13-2009, 08:05 AM   #2
Thta is the responsibility of the landlord or owner. Tenants can't make repairs or improvements without approval.
That said, paint only covers up the problems, it does not fix them. I am not sure how bad that bottom slab is, but surface fixes rarely last long. It probably needs to dug up and replaced. There is a product called Top'N'Bond that is one of the better cement patching products. But no guarantees it will last, especially if you are in a cold climate with a lot of freeze/thaw cycles.
Old 09-13-2009, 11:51 PM   #3
you don't have improvement nor repair rights if a tenant except by express agreement & permission,,, that said, you could try polymer-modified repair mtls which're NOT avail at apron stores but would be vastly more permanent than top 'n' bond.
no paint adheres permanently to conc altho there're coatings that we use & have been in place for over 20yrs w/o any degradation.
itsreallyconc is offline   Reply With Quote
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 12:55 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-23-2008 12:22 AM
Concrete steps Shadowchase Building & Construction 5 07-04-2008 07:01 PM
