Old 08-08-2011, 02:20 PM   #1
John Ross
JohnRoss's Avatar
Repairing concrete slab in shower
I need advice on repairing a concrete slab. I am enlarging my shower. The original shower has a 3 inch recessed concrete pan in the concrete slab. I have removed the concrete slab around the original drain. I removed the concrete in part of the recessed concrete pan so I could relocate the drain. I need to patch the concrete area where the old shower pan slab was removed. I also want to bring the old recessed concrete shower pan up to the height of the rest of the home slab. I assume I would coat the old shower pan concrete with a concrete bonding agent then mix and pour Sakrete Concrete Mix 5,000 PSI Fiber-reinforced into the old pan and cut out slab area?
I am not sure if this is the correct way to repair the slab?
JohnRoss is offline   Reply With Quote
concrete block house shower medalta Building & Construction 3 11-02-2011 06:16 AM
To Remove Concrete Slab in Bathrooms? fletch7 Remodeling 7 08-05-2011 09:58 AM
Repairing water damaged shower entry 2sents Tiling, ceramics, marble 21 01-09-2011 09:52 AM
Shower drain in concrete slab. tarogers5 Plumbing 1 07-16-2010 03:24 PM
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 01:47 PM
