Repairing Concrete Mortar Siding With Exposed Crushed Rock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 10:05 PM   #1
Post
Repairing concrete mortar siding with exposed crushed rock
Could anyone offer suggestions as to where I might purchase 3/8" washed crushed rock for repairing damaged areas (and corners) of my old painted concrete mortar siding which has exposed crushed rock stuck throughout siding? Is the mortar mix the same as brick mortar? Any help would be much appreciated. Ray
bridgerunner is offline   Reply With Quote
Old 11-20-2009, 07:09 PM   #2
Yes it can be done by a DIYer. Where to buy is going to depend on how much you want to spend. You will need a complete track system. They can be bought from the big box stores to custom door companies.
Install radiant floor heating systems reviews | Best electric radiant floor heat | Radiant floor heating systems
getioned is offline   Reply With Quote
Old 11-20-2009, 07:44 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
If you are worried about the aggregate, start by looking at the nearby aggregate sources since typically, the shipping cost is greater than the cost of the aggregate.
A second source would be the the local packager of the mix if you thinks it was supplied withing the packaged mix that was used.
Dick
concretemasonry is offline   Reply With Quote
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
Concrete Walkway with Exposed Aggregate BTn5qsc2zB93ztGN9vJP Landscaping & Lawn Care 4 08-22-2008 07:49 AM
concrete from mortar Wahoo Building & Construction 14 03-07-2008 11:15 PM
Concrete Support for Rock Fountian ? Piney Building & Construction 1 09-19-2007 06:43 AM
concrete lap siding warnerww Building & Construction 2 04-29-2007 10:53 PM
