Repairing Basement Walk Out Stairs (Cracks/Leaks) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 11:46 AM   #1
Rewards Points: 16
I need to repair the bottom step and possibly the framing around the walkout basement stairs.
http://www.flickr.com/photos/cjfry/s...7626622384860/
If you view the pictures, youll notice that there are some chunks missing. Water comes from underneath the stairs (fround the ground) and leaks in.
The framing on the rights side has some issues, or appears to, as well. Not sure how to fix the gap there between the wood and the concrete.
I planned on using hydraulic cement for the concrete stairs. Is that my best bet?
Also, any ideas for the gap between framing and concrete on the right side?
JakeFV is offline   Reply With Quote
Old 05-01-2011, 03:57 PM   #2
Rewards Points: 5,336
Hydraulic cement works well with deep holes with parallel walls. Useless to parge a flat surface.
I would identify where the water is coming from and try to eliminate or reduce it from this area. Regrading the soil, extending the leaders, underground perforated piping, etc.
Once you minimize the water you can address the stairs more easily.
I'd switch out the wood brick molding with a composite material.
Ron
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Painting basement stairs rredogg Painting 11 04-18-2011 07:32 PM
Walk out basement insulation comet Building & Construction 0 09-07-2010 04:08 PM
Basement egress stairs June Benninger Building & Construction 0 08-07-2010 01:54 AM
Basement Stairs Repair tmbrink Building & Construction 5 03-18-2009 06:08 AM
