Repair/ Support Garage Rafters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 08:12 PM   #1
posty23's Avatar
Repair/ support garage rafters
So I just bought this house and of corse the inspector missed this upon many other things. The garage is 17' wide by 20' deep. For the most part everything seems to be constructed well, but the previous owner damaged the rafter/ joist? Not real familiar with the terminology but as you can see they tried to fix one of the splitting beams by bolting a 2x4 on both sides of it. There are 3 beams that are cracked/splitting that need to be repaired. I would really like to put some light storage on these beams when finished; Christmas decorations, old boxes, but nothing real heavy. I was wondering what a good solution to this problem would be and what else I would have to do to make it usable. I have read some similar stories and sintering the cracked areas with plywood or 2x6 pieces has been a common solution. Also maybe running a header type beam across the middle of the beams to help support the load was an idea. Any help would be greatly appreciated as I am trying to rectify this problem as soon as I can. Thanks
Repair/ support garage rafters-image-3976583752.jpg
posty23 is offline   Reply With Quote
Old 04-01-2013, 08:36 PM   #2
An old Tradesmen
Rewards Points: 8,236
Moved to Building and Construction forum.
Old 04-01-2013, 08:42 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
it appears from what I can see in your photo the 2x are acting as rafter ties to prevent rafter thrust from pushing out the tops of the load bearing walls. the simple fix would be install another 2x along side that one.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-01-2013, 09:01 PM   #4
posty23's Avatar
Here are some more pics.
Repair/ support garage rafters-image-1710923429.jpg   Repair/ support garage rafters-image-3551852558.jpg
Old 04-02-2013, 09:14 AM   #5
Rewards Points: 14,312
Those were never designed for any form of storage or down loading.
I'd guess someone tryed using one to lift something, like the the front of a lawn mower or and engine, anyone guess what they did.
For storage you would need to use something like 2 X 10's at least every 24" or build a center wall or beam to support it.
I'd also bet there's no foam baffles under that insulation which will super heat the roof.
There should have been baffles, soffit vent and a ridge vent.
Old 04-02-2013, 10:22 AM   #6
Rewards Points: 150
I don't think that's a big deal. As mentioned above, they're to keep the outside walls from pushing out. As long as the cracked beam is securely tied across the crack, it shoud last. A repair / nail plate would have been a better choice than some boards.
If you want storage, maybe this will help... these beams were similar. Upgrade to 2x6's (or bigger) and put them every 2' to match the spacing of your rafters. Hurricane tie the rafters to the joists to the top plates. You probly just have toenailed rafters there. You might need just over 20' lengths to sit on the top plate on both ends which will be hard to find. We had to order from a lumber yard.
Of course put in as many new ones as you can first. When you're sure your walls are safely tied together, then replace the old ones.
Before:
After:
SquishyBall is offline   Reply With Quote
Old 04-02-2013, 11:11 AM   #7
Roofmaster
Rewards Points: 2,210
What was the home inspectors name, Mo, Larry, or Curly?
And as a general question, how the hell do these guys get away with calling themselves inspectors ?????
Observers, maybe. Ignorant Observers, Probably. But Inspectors?????
This guy did not even know enough about what he was looking at to recommend a structural engineer ?????
Garage storage in rafters? kirwinjd Building & Construction 17 09-26-2014 09:31 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Garage door repair kpshulman General DIY Discussions 6 09-08-2009 12:01 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage Door Repair sherlock General DIY Discussions 9 05-08-2008 03:26 PM
