Repair A Subfloor From Crawl Space? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 02:33 PM   #1
Hello-
Is it possible to fix a subfloor from the crawlspace? We have dry rot under a shower in a bathroom that is tiled. The dry rot is about 3x3. This will prevent my from having to gut out all the tile which would then require basically a complete bathroom remodel since the tile can't be color matched.
Thoughts? Thanks!
mushman is offline   Reply With Quote
Old 01-30-2011, 03:03 PM   #2
Experienced
Jackofall1's Avatar
First - Sorry to hear of this, have you found where the water is leaking from to cause this rot, as it really doesn't matter what you do to fix the results until you find the problem you will gat the same results.
I really don't think that the subfloor can be fixed from underneath, given the repair area is larger than the space typically found between floor joist, and tile will not support itself while you remove the rotten pieces.
Mark
Old 01-30-2011, 03:44 PM   #3
Thanks for the help. I should I mentioned that yes, I found the leak and its fixed (bad drain seal). I guessed that there would be a problem with what you mentioned re: tile support and beam distance. Thanks for confirming this.
Thanks again.
Tags
shower , subfloor , tile
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 08:32 AM
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 05:58 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
