Repair Rotten Wall Stud Next To Window - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 03:55 AM   #16
If that was made in the 1950s, you might have some trouble getting dimensional lumber to fit properly. Can't really tell from the photo but it could be true 2x4, unlike the modern stuff which is rough cut to 2x4, then planed so it loses 1/2 inch so that they are really 1 1/2" x 3 1/2", ish. Different lumber mills have slightly different plane depths. I've seen up to 1/4" difference between two pieces of the "same" lumber sizes from different mills. Frustrating as hell to work with....
But, if it is raw lumber size, you can contact a lumber mill and get the wood from them raw.
weekendwarrior9 is offline   Reply With Quote
Window in basement wall Bigin429 Building & Construction 0 03-05-2012 08:36 PM
Rotten Stub and bottom plate against exterior wall markx Carpentry 2 05-26-2011 11:51 PM
Need to move stud in finished partition wall juengl4 Building & Construction 7 02-18-2011 08:36 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
