Repair Rotted Wood Core In Exterior Metal Door. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 04:09 PM   #1
Repair rotted wood core in exterior metal door.
My exterior metal door has a wood core. The bottom corner has rotted. Is there a way to repir that small section of rotted wood?
jnowak is offline   Reply With Quote
Old 05-04-2009, 04:49 PM   #2
Old School
Willie T's Avatar
Check out "Penetrating Epoxy". (Here is a link to just one of many brands)
This stuff is injected into the existing wood with needles, and no extraction or removal of any wood is necessary. We use it here in Florida on boats all the time. It's simple to use, and makes a rock-hard, rot impervious repair.
Willie T
Old 05-04-2009, 04:55 PM   #3
Rewards Points: 5,336
The problem with this, is that the metal skin is incorporated into the wood frame through bending it into a profile. Removing the wood sets the metal free from the profile. You could remove the rotted perimeter wood. Route a similiar profile and dropping them in place. Apply construction adhesive to mate with the old wood. You will need to remove some of the foam insulation core to get the pieces in the frame. After the adhesive sets, drill a hole in the botton and shoot in some slow expanding foam to take the place of the foam you removed. Clamp all the sides until the foam has cured.
Prime and paint.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Hole in wood door Sliding Man Carpentry 12 07-09-2008 07:54 PM
Hanging towel bar in hollow core door. ERIK2173 Remodeling 1 02-06-2006 07:19 PM
