Repair Or Rebuild? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 07:00 PM   #1
Repair or Rebuild?
I live in Largo, Fl. We have owned this home for two years (our first). We have discovered shower damage. My question is can this be repaired or does it need to be rebuilt. I know the window has to go no matter what! Here are some pictures of the partially demo'd shower. It gets much worse below and behind the tub. Also the sheathing is falling off the stucco.
revflyer is offline   Reply With Quote
Old 10-05-2011, 07:16 PM   #2
DIY staff
Rewards Points: 7,174
Not sure exactly what you are asking----your framing can be rebuilt from the inside without having to rip apart the exterior--
Some better lit pictures would help---
Pull the tub so we can see the extent of the rot----Mike---
Old 10-05-2011, 07:31 PM   #3
I will probably get to the tub this weekend. how would I repair the sheathing coming off the stucco from the inside. Here are some more pics. the first two are behind the tub, the third is the stucco and the last is under the window
Name:  Behind tub 1 small.jpg
Name:  Behind tub 2 small.jpg
Name:  Sheathing off stucco small.jpg
Name:  Under window small.jpg
Old 10-05-2011, 07:48 PM   #4
DIY staff
If the sheathing is shot the outside will need to be removed---You mentioned the window--so the stucco would need to be replaced anyway---consider a thin slit type of window.
Nice light but high enough to avoid direct blast of water from the shower.
revflyer (10-05-2011)
Old 10-05-2011, 08:07 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
It would also limit your, er..."exposure" to your neighbors. Try googling "transom window". I think that is what they are called.
Old 10-06-2011, 07:50 AM   #6
DIY staff
Thanks for the pictures----I don't see any tar paper behind the stucco---there's the cause---
Might be time to call your insurance company---that damage may be covered under your homeowners insurance----The rest of the house should be checked with a moisture meter.
Old 10-26-2011, 10:06 PM   #7
it's more appropriate to rebuild because as what the pictures of yours trying to imply the wood are being rotten already . it maybe due to a range of time that it wasn't given attention to be repaired. when it is repair we don't know that there may be ongoing problems with it so it's better to rebuild it to be properly secure.
Kaylee is offline   Reply With Quote
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 03:02 PM
