Repair Outside Block Crack - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 01:26 PM   #1
Rewards Points: 174
Repair outside block crack
Hey All - whats the best way to repair the crack/hole in the pic below? This is on the side of my house with the crawl space being right on the other side....
tb582 is offline   Reply With Quote
Old 08-01-2010, 01:38 PM   #2
Rewards Points: 5,336
Dig away the soil and expose the joints. Wash the soil out of the bad areas. Probe the joints around the open area to make sure you get all the bad joints exposed. Use a mortar mix to fill the open areas.
Ron
Old 08-01-2010, 06:24 PM   #3
Rewards Points: 4,656
that type of repair's called an ' underpinning ',,, use conc mix instead - we do !
Old 08-01-2010, 08:08 PM   #4
Rewards Points: 174
do you fill in the hole in stages or do you some sort of metal mesh wire to hold the concrete patch?
Old 08-01-2010, 08:35 PM   #5
we excavate as the situation requires & place 2 bisecting mats of # 5 rebar to meet local code.
Old 08-02-2010, 11:24 AM   #6
Rewards Points: 174
How do you make the rebar stay?
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 03:57 PM
crack repair help beerdog Drywall & Plaster 6 02-07-2010 04:38 PM
Pls help! DIY foundation crack repair question tspaulin General DIY Discussions 3 07-16-2009 07:39 AM
Ceiling Crack Repair Speckert Building & Construction 7 12-29-2008 10:03 AM
found an old foundation crack in block floor to ceiling flashme18 Building & Construction 14 11-11-2008 09:15 PM
