Repair Frame For Garage Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2011, 12:38 PM   #1
Rewards Points: 178
Repair Frame for Garage Door
My garage currently doesn't have a garage door and I was told by a handyman that before I could have one installed I needed to repair/rebuild the frame beforehand. He said this because the left and right frame of the opening were wobbly and the bottoms have wear and tear.
Below is a link to photos I took from inside the garage. If I was to tackle this myself how would I go about fixing this problem?
https://picasaweb.google.com/1137698...eat=directlink
Thanks in advance
P.S. - Its a two car garage and I believe the opening was built for a 16' x 7' garage door.
anuvanoob is online now   Reply With Quote
Old 11-21-2011, 05:01 PM   #2
Rewards Points: 5,336
The only thing I see is that the bottom plates on both sidea are gone. If they're gone, I'd check the rest of them.
The garage rests on the plates. If they're shot, the structure of the building is at risk.
Ron
B. Franklin 1759
Old 11-21-2011, 06:39 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 674
Send a message via Skype™ to AndyGump
The framing looks fine but as Ron said, the bottom plates should be removed and replaced. That is not a super hard thing to do for a DIY'er with skills.
Is there a block wall at the back of the garage too?
Andy.
AndyGump is offline   Reply With Quote
Old 11-21-2011, 08:42 PM   #4
Rewards Points: 178
Yes, the back wall is brick too (see photo: https://picasaweb.google.com/lh/phot...eat=directlink).
What do these bottom plates look like? What exactly do they do?
Old 11-21-2011, 08:54 PM   #5
They're the base of the structure.
Ron
B. Franklin 1759
Old 11-21-2011, 09:00 PM   #6
AndyGump's Avatar
Rewards Points: 674
Interesting, the plates should be pressure treated lumber, 1-1/2" thick and at least as wide as the framing.
You may need to use red-head type anchors or wedge type to secure them to the conc. I would recommend putting a six inch concrete wall under them as long as you will be temporarily holding up the front wall anyway.
This will keep the plates from being water-logged and deteriorating as they obviously have.
Andy.
Old 11-21-2011, 09:19 PM   #7
Rewards Points: 178
so that metal thing screws into the bottom beam and then screws to into the concrete floor? Or into some concrete block I gotta make?
Old 11-21-2011, 09:35 PM   #8
For your situation, ignore the metal thing.
You need to learn some terminology. From your posts, you have no working knowledge of carpentry.
Do a search of Framing terminology and look at the pictures and the descriptions. Then compare it to your situation. You will then understand better the issue you have.
This "handyman" guy couldn't explain this to you while he was there? Didn't offer to repair the situation?
Are you asking these questions to understand what the issue is or are you contemplating the repair yourself?
Ron
B. Franklin 1759
Old 11-21-2011, 10:51 PM   #9
Rewards Points: 178
Well that's why I'm here - I don't know the terminology. I did do several searches and had no luck so I turned to this forum.
The handyman was on-site to give us a bid on a different job - I asked, in passing, about how hard it would take someone like myself to put a garage door on, he took a quick look, made us aware the frame was actually wobbly, proceeded to explain the repairs and it went over my head. Since it wasn't priority at the time I put it on the backburner for another day.
I just bought this house, I'm a first time homeowner and I would like to understand what the issue is and I want to repair it myself. I'm a fast learner, technically inclined, far from lazy and very patient, so there's no question I can perform the work, I just need help getting started.
Old 11-22-2011, 06:51 AM   #10
http://www.google.com/search?q=garag...x=&startPage=1
Here's something to get you familiar with the terminology. There are videos included in the link.
Ron
B. Franklin 1759
Old 11-23-2011, 11:57 AM   #11
Rewards Points: 178
Thanks for the help so far, I really do appreciate it.
Old 11-26-2011, 12:44 AM   #12
Rewards Points: 178
Okay, so after going through a couple of Ron's search results I think I got my game plan: remove the king and jack studs, fasten new bottom plates to the concrete using pressured treated lumber and split drive concrete anchors adding a layer of roofing shingle between the lumber and concrete for added protection against water and finally install new king and jack studs. Am I good to go?
Old 11-26-2011, 07:20 AM   #13
If the king and jack studs aren't damaged, there's no reason to remove them. Slightly jack up the area, cut the bottom plate and the nails out and slide another PT wood plate in. Then lower the wall and fasten the wood to the floor and the studs.
You might have to do this in other areas as well. This is usually a comprehensive issue.
Ron
B. Franklin 1759
Old 11-26-2011, 10:36 AM   #14
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
The garage door opening needs to be framed, inside to inside, the same size as the garage door will be. In your case the door will be 16 feet even. If you remove anything from the garage door opening, be sure to have the header supported with a couple of 2X4s so it don't come down when you replace the damaged wood. You will want to replace any damaged wood such as plates and studs before installing the framing for the door.
The framing for the garage door should be 2X6 or 2X8 with the top 2X sloped at a slight angle to let water run out instead of in. These 2Xs will need to be nailed flush with the inside framing. The side 2Xs of the door framing need to be treated and held 3/8 to a 1/2 inch off the floor to keep water from wicking into the wood.
Just another concern, I am not sure a garage door can be installed on an angle such as the ground at the front of your opening is.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 11-26-2011, 10:43 AM   #15
Rewards Points: 178
Okay. Well, the bottom of the studs are water-logged and deteriorating so I'm assuming I better remove them (plus keeping them in and jacking up the front for the new bottom plates will push my opening height to ~7' 1 1/2" which is not standard and would make installing a garage door more difficult). Also the current bottom plates were nailed to the king studs only and the plates themselves are only about a quarter inch thick (they don't even touch the floor/concrete), so it appears the previous owner Mickey Mouse'd this build (as with everything else in this house).
The back wall is just cement blocks, so I don't have to repair anything back there.
Wind Caused Damage to Front Door Frame...Help? agentphish Carpentry 8 03-14-2011 04:37 PM
How to frame door under hvac duct cai Building & Construction 5 06-15-2010 07:05 PM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Stanley Vemco Garage door opener repair 616Kenneth General DIY Discussions 1 08-12-2006 07:11 AM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 11:00 AM
