| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Fix a Brick Stair Leak
by eHow.com
If after a rain you notice water collecting underneath your brick stairs, then you may have a brick stair leak. Afraid that you will have to spend thousands of dollars to have your stairs rebuilt? Slow down--this might not be the necessary solution. Read... Read More » The dry-mortar method is an easy way to fill the space in masonry joints when you're building a patio. One of its advantages is that the mortar keeps those pesky weeds from sprouting. Whether you're using bricks or concrete slabs, consider filling the... Read More »
How to Lay Bricks in a Running Bond
by eHow.com
If you're creating a curtain wall with bricks, then you may use a running bond. The running bond isn't visually interesting but is very commonly seen because it's one of the easier bonds to create. If you aren't certain how to lay a brick running bond... Read More »
How to Build a Masonry Planter
by eHow.com
Making a masonry planter is a good way to add aesthetic value to your home. They work well in yards and can also be used to add foliage to areas that are covered in concrete, tile or other non-dirt surfaces. Read More »
Adding Rows of Bricks to a Back Yard Grill Pit
by Expert Village
Hi, I'm Mark Sullivan for Expert Village and today we are going to learn how to build a barbeque pit. So we have our next course in place. So I think then we will continue with setting another course of bricks to the next level and again, I think we will... Read More »
