Repair A Big Hole On My Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 10:20 AM   #1
Repair a Big hole on my Basement wall
Hi, I replaced my old boiler and water heater tank with a new combi boiler, so right now I have a big hole on my basement wall. This hole was for the boiler and tank vent and this vent is on the chimney. I would like to know what is the easy way to repair this concrete wall. I was thinking to fill it first with one of those filling foams and then I will put some concrete on top of that. I was wonder if this is ok since the hole is on the chimney vent. Thanks
amb1s1 is offline   Reply With Quote
Old 10-07-2013, 10:34 AM   #2
cortell's Avatar
Rewards Points: 504
A picture (or two) is worth a thousand words.
cortell is offline   Reply With Quote
Old 10-07-2013, 11:10 AM   #3
I attached a picture. I put the window on the picture for size reference.
Old 10-07-2013, 11:11 AM   #4
Maybe after I use the foam I can stick couple of metal sticks so the concrete have something to hold.
Old 10-07-2013, 01:31 PM   #5
AHH, SPANS!!!
Rewards Points: 1,166
I'd fill with brick or block using mortar and skim/stucco over it all after filled, might have to let brick/block dry some before skimming
hand drive is offline   Reply With Quote
Old 10-07-2013, 01:53 PM   #6
When you say dry, what do you mean?
Old 10-08-2013, 08:18 AM   #7
AHH, SPANS!!!
let the mortar dry/set up in the filler some before skimming over it with more mortar.
Old 10-08-2013, 08:34 AM   #8
PoleCat's Avatar
Rewards Points: 1,652
I moved an 8" round duct that went from our basement into the crawl space to a different spot and the old hole was patched just as you're thinking. I filled the void with the triple expanding foam and left it to cure. Then a put a dozen or so long drywall screws in the foam and mortared it over. Its been 20 years ago and it still looks great.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-08-2013, 11:07 AM   #9
Rewards Points: 274
Try what the PoleCat has done 20 years ago and might be it repair the hole of wall in better way.
alexjoe is offline   Reply With Quote
Old 10-08-2013, 01:36 PM   #10
I already fill the hole with bricks and mortar. It look good. Thanks for all the replies
Old 10-10-2013, 11:28 AM   #11
Final result. Is not beautiful, but this wall is going to be frame and Sheetrock.
Old 10-10-2013, 03:08 PM   #12
cortell's Avatar
Rewards Points: 504
Thanks for posting. It's nice to see someone take the time to share a picture of the end result. It's a bit more gratifying to those who took the time to answer questions.
Old 10-10-2013, 03:20 PM   #13
I always try to do. Thanks again
Basement foundation wall repair? ronnoez Building & Construction 8 12-06-2011 11:05 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
A hole in the basement wall handifoot Building & Construction 10 01-08-2009 09:14 AM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
