-   -   Repair a Big hole on my Basement wall (http://www.diychatroom.com/f19/repair-big-hole-my-basement-wall-188181/)
amb1s1 10-07-2013 11:20 AM
Hi, I replaced my old boiler and water heater tank with a new combi boiler, so right now I have a big hole on my basement wall. This hole was for the boiler and tank vent and this vent is on the chimney. I would like to know what is the easy way to repair this concrete wall. I was thinking to fill it first with one of those filling foams and then I will put some concrete on top of that. I was wonder if this is ok since the hole is on the chimney vent. Thanks
cortell 10-07-2013 11:34 AM
A picture (or two) is worth a thousand words.
amb1s1 10-07-2013 12:10 PM
1 Attachment(s)
I attached a picture. I put the window on the picture for size reference.
amb1s1 10-07-2013 12:11 PM
Maybe after I use the foam I can stick couple of metal sticks so the concrete have something to hold.
hand drive 10-07-2013 02:31 PM
I'd fill with brick or block using mortar and skim/stucco over it all after filled, might have to let brick/block dry some before skimming
amb1s1 10-07-2013 02:53 PM
When you say dry, what do you mean?
hand drive 10-08-2013 09:18 AM
let the mortar dry/set up in the filler some before skimming over it with more mortar.
PoleCat 10-08-2013 09:34 AM
I moved an 8" round duct that went from our basement into the crawl space to a different spot and the old hole was patched just as you're thinking. I filled the void with the triple expanding foam and left it to cure. Then a put a dozen or so long drywall screws in the foam and mortared it over. Its been 20 years ago and it still looks great.
alexjoe 10-08-2013 12:07 PM
Try what the PoleCat has done 20 years ago and might be it repair the hole of wall in better way.
amb1s1 10-08-2013 02:36 PM
I already fill the hole with bricks and mortar. It look good. Thanks for all the replies
amb1s1 10-10-2013 12:28 PM
1 Attachment(s)
Final result. Is not beautiful, but this wall is going to be frame and Sheetrock.
cortell 10-10-2013 04:08 PM
Thanks for posting. It's nice to see someone take the time to share a picture of the end result. It's a bit more gratifying to those who took the time to answer questions.
amb1s1 10-10-2013 04:20 PM
I always try to do. Thanks again
