Old 10-31-2009, 09:31 AM   #1
Handyman
Default renting rooms
I was asked recently about renovating a basement for rental use. I can't find any building codes which need to be addressed. Are there any 'general guidelines' in regards to the amount of rooms, fire safety and electrical/ HVAC issues?
canadaclub is offline   Reply With Quote
Old 10-31-2009, 01:44 PM   #2
Minimum ceiling heights and alternate egress will probably be issues. All other plumbing, electrical, etc. codes for living spaces will apply too like GFCI outlets in bathroom and kitchen.
sdsester is offline   Reply With Quote
Old 11-04-2009, 01:16 AM   #3
Also, don't overlook the possible zoning violation. If your property is zoned for single family, then you can't add a separate living space.
phxinsp is offline   Reply With Quote
Old 11-04-2009, 01:59 AM   #4
Building codes guy, Mod
thekctermite's Avatar
That's absolutely correct. Subdividing an existing home into multiple units will often be a zoning problem.
Additionally, the creation of a separate living unit within the structure will likely require rated fire separation from the upstairs living space. That is a major undertaking.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
More On This Topic
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Hi! I am Angela on behalf of expertvillage.com, and right now I am going to be taking about posture and the pains that can be induced from poor ergonomics and posture. Ergonomics is how your back is positioned and how your chair is structured. If it is... Read More »
Stripping hardwood - renting a sander irishgem@ymail. Flooring 12 07-05-2009 10:02 PM
Forced Hot Air Furnace - cold rooms? ddave23 HVAC 0 01-23-2009 10:47 AM
adjoining rooms getting out of square on engineered wood installation jencastro Flooring 5 09-22-2008 11:58 AM
Adding rooms under cottage billybarty Building & Construction 17 03-10-2008 11:01 AM
Design rules for wood floors in adjacent rooms chrish Flooring 1 09-10-2007 09:04 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
