Renovating Entire Basement --- Tips - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 01:59 PM   #1
Rewards Points: 160
Hello,
Doing a complete gut except leaving studs in place. Live in Canada, just a few questions...and thanks
1) Half the walls have plastic right against the foundation concrete vs other walls have the barrier on the inside of the studs- remove or just leave as is?
2) I have big screen tv downstairs - my wife wants me to soundproof - also without the walls the furnace sounds like a jet engine (well not that bad) so do I just use Roxul? And if i use Roxul would I foam the point where the joist meets the floor and then roxul and then apply tape from joist to roxul? I have heard from some forums that roxul didn't do a think to dampen the sound...I don't want to spend a ton of cash, just want to turn the volume down
3) How should I wrap the duct work? Just aluminum foil on the joints or should I wrap it with the acoustic seal insulation or maybe just use some expanding foam around it? I don't know
4) Good idea to wrap copper plumbing pipes with anything?
5) A site also mentioned putting "padded tape" inbetween the joists and the drywall to dampen sound.
6) I also am remodeling a brick fireplace - instead of breaking out the brick and putting new brick in - I have heard you can just cover the old fireplace with backer board and apply new brick to the backer board.
7) I want to soundproof the furnace room - which also has our central vac in it ... Anything special to worry about when doing a furnace room? Fireproofing or doubling the soundproofing material, etc???
Thanks..also if you have any suggestions for something I may be overlooking...thanks
hellothere123 is offline   Reply With Quote
Old 01-15-2011, 07:29 AM   #2
Stay-at-home GC
All sound like good ideas.
Not sure if backerboard is necessary over the old brick fireplace. If you are thin-bricking I would go expanded metal lath, screwed to old mortar joints then scratch coated. Apply thin-brick to scratch coat.
Be aware that lath does have a right and wrong side up. Install it upside down and your install will fail early. Run your hand across it, one way is smooth, the other grabs. Grab should point up
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
The Following User Says Thank You to CplDevilDog For This Useful Post:
oh'mike (01-15-2011)
Old 01-15-2011, 09:19 AM   #3
ccarlisle's Avatar
Gee Canada is a big place, wouldn't you agree? So where are you? I ask that because the answers you arrive at will differ whether you live in Victoria, Windosr or Fort McMurray.
So, first tip is I'd say read up on vapour retarder placement and soundproofing before you ask for how-to-do-it tips as then you can act critically instead of talking our word for it...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 01-25-2011, 12:39 PM   #4
Soundproofing Guy
Rewards Points: 158
http://www.soundproofingcompany.com/..._construction/
http://www.soundproofingcompany.com/...cles/flanking/
http://www.soundproofingcompany.com/...within_a_room/
These are quick reads but will give you more intuiton as to what to do.
Ted White is offline   Reply With Quote
Old 01-25-2011, 10:34 PM   #5
yummy mummy's Avatar
Rewards Points: 1,016
ccarlisle; nice to see you are still around here......happy new year.....
yummy mummy is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
