Old 05-18-2012, 12:13 PM   #1
removing wood siding
My contractor sided my 2 story house with untreated 21/32 interior pine paneling installed horizontally. Yea, I sued and won. The siding is stapled every 8 inches, top and bottom of panels.
The paneling is highly warped, so I will have to tear it off. I plan to install Hardie Plank.
I can rebuild a SBC in the dark and know which end of a hammer to hold, otherwise I am a noob and would like to head off problems before they arise.
dcstarbuck is offline   Reply With Quote
Old 05-18-2012, 12:17 PM   #2
Moderator
kwikfishron's Avatar
Posting pictures and asking specific questions would be a good start.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 05-18-2012, 07:48 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
are you planning on hanging the harti yourself , unless you have experience hanging siding , fibre cement isnt a diy project. if you want the product to last it has a very strict installation procedure to follow if you want the warrenty intact
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Ravenworks (05-18-2012)
Old 05-19-2012, 12:28 AM   #4
Moderator
If the siding is too difficult to pull off, cut along the studs on one side only first, then try to rotate each individual board loose. We can help you DIY with the Hardie! What is a SBC?
Gary
P.S. Welcome to the forums!
Clothes taking longer to dry?
Old 05-19-2012, 06:05 AM   #5
Moderator
I’m not sure why you think installing Hardie isn’t DIY or that it's more difficult than other types of siding.
The installation guide is only 4 pages and illustrated, nothing confusing about it.
In fact throw in a couple of cam gauges and Hardie is about as easy as it gets.
-NEW MEMBERS-
Old 05-19-2012, 07:30 AM   #6
I've never seen interier "paneling" that thick. Sure sounds like they used T-111 and installed it horz.
Old 05-19-2012, 08:01 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
[quote=dcstarbuck;924022]My contractor sided my 2 story house with untreated 21/32 interior pine paneling installed horizontally. Yea, I sued and won. The siding is stapled every 8 inches, top and bottom of panels.
The paneling is highly warped, so I will have to tear it off. I plan to install Hardie Plank....[quote]
That guy could not be legit contractor, more like a = HACK
- Build Well -
Old 05-19-2012, 09:18 AM   #8
AHH, SPANS!!!
if there is any type of overlap involved with the siding to be pulled off then it is always easiest to start tearing off at the top and work down from there. otherwise you are constantly fighting with the overlap from the siding piece above...
hand drive is offline   Reply With Quote
Old 05-19-2012, 09:39 AM   #9
Framing Contractor
Do you have a question...or is this going to be a guessing game for everyone?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-19-2012, 06:28 PM   #10
Thanks to all. I do plan a DIY job. The contractor proved that old adage of doing it yourself. I will post pictures soon and sure I will have more specific info. I don't think it will be difficult removing.. the wind has started the project.
Oh, SBC Small Block Chevy
Old 05-19-2012, 06:48 PM   #11
Moderator
LOL, Thanks, up past my bedtime with a week-long cold. (And I was a diesel mechanic for 4 years, even more embarrassing....) Now you know why I don't text. Sounds like T1-11 structural siding, as someone pointed out; good guides at top-right, though no horizontal applications;http://www.apawood.org/level_b.cfm?content=prd_sid_main
Gary
Old 05-19-2012, 07:00 PM   #12
Moderator
Everyone that's responded so far is a Contractor (or in the trades). The guy that worked on your place is an exception.
Looking forward to the pictures.
Btw, Welcome to the Forum.
-NEW MEMBERS-
removing the old wood lap siding jbjones Building & Construction 3 05-10-2011 07:15 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
