Removing Wallpaper - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 05:37 PM   #1
removing wallpaper
How do I remove wallpaper that has been glued onto the wall? Would steam work?
Van3 is offline   Reply With Quote
Old 01-30-2011, 05:55 PM   #2
DIY staff
Rewards Points: 7,174
Steam will work---First try the simplest method,however---
Go to the store and buy a bottle of DIF wall paper remover (It's a soapy enzyme that softens the wall paper paste)
Also get a paper scorer --(round plastic tool with little gears)-That will quickly poke a thousand little holes through the face of the paper so the water and DIF can reach the paste.
You will get the paper wet using the water/Dif solution--when the paste softens--remove the paper with a wide putty knife----clean the remaining paste off the wall with a green scrub pad and soapy water.
Wipe with clear water after the paste is scrubbed off.
I use a plastic garden spray pump--less messy than applying the DIF with a sponge or paint roller.
Some drywall patching may be needed-----Plenty of posts here on that---Mike---
Van3 (01-31-2011)
Skim Coating wall After removing wallpaper stevenson66 Painting 6 11-08-2010 07:35 PM
Removing wallpaper redheadps Drywall & Plaster 5 07-20-2010 10:24 AM
Removing Wallpaper Paste Bliss7777 Painting 13 08-07-2009 04:46 AM
Removing Wallpaper fcamargo6thave Painting 17 04-27-2009 02:59 AM
Removing wallpaper and repairing plaster walls Boroco General DIY Discussions 3 03-27-2009 01:27 PM
