Removing Wall Tiles - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 01:55 PM   #1
removing wall tiles
I have a broken wall tile (circa 1972)
I found a close match. I want to remove one near the floor to install in the conspicuous location and put the one I found where it won't be noticed.
How can I remove an individual tile without damaging it?
pyper is offline   Reply With Quote
Old 02-17-2011, 03:20 PM   #2
If it was installed properly I'd say you're are pretty close to SOL.
jod78 is offline   Reply With Quote
Old 02-17-2011, 03:30 PM   #3
You could try it, but jod78 is prob right. There are places that will have a match but will cost you an arm and a leg
mrgins is offline   Reply With Quote
Old 02-17-2011, 03:53 PM   #4
A door a day is all I ask
TheDoorGuy's Avatar
If you can access one that is on an end you can probably work flexible putty knife or other long blades
under it enough to separate piece from wall. Work slowly and try to damage wall instead of tile.
I don't think there is a good way to remove one with all four sides enclosed by other tiles or surfaces.
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 02-17-2011, 04:24 PM   #5
Bummer.
The one I got is a near match, and that's probably close enough.
$0.50 at Habitat for Humanity store.
Thanks.
Old 02-17-2011, 05:27 PM   #6
TheDoorGuy's Avatar
It will add character!
Be careful not to damage surrounding tiles when you remove the broken one.
RC/DG
www.thedoorguy.com
Old 02-17-2011, 06:12 PM   #7
A Little Of Everything
Rewards Points: 1,364
Yep. What he said. ^
While you're at the Habitat Store, be sure to pick up several tiles.
Remove the broken one. Then carefully try to remove one along the floor, or behind the toilet. If it breaks, you can replace it too. If it doesn't break, you've got your match.
Good luck!
DrHicks is offline   Reply With Quote
Old 02-18-2011, 09:13 AM   #8
How about getting some decorative tiles and replacing several of the originals? Just a thought
Old 02-18-2011, 05:54 PM   #9
Rewards Points: 154
That's a good thought as it would look like an original pattern but my guess is he'd rather stick a fork in his eye than remove more tiles than necessary.
pete0403 is offline   Reply With Quote
Old 02-18-2011, 09:33 PM   #10
Aw come on! It's not that hard to do
Old 02-18-2011, 10:04 PM   #11
Rewards Points: 212
just tak a sledgehapper and go nuts like all the diy shows
bluebird5 is offline   Reply With Quote
Old 02-19-2011, 08:09 AM   #12
Hopefully you can get some nut-job constantly screaming into a bull horn, just to add atmosphere.
Old 02-19-2011, 08:44 AM   #13
Old School
Willie T's Avatar
Use a long, pointed drywall type saw (or I use a Multi-tool) and saw out the whole tile... wall backing with it. (after you have grooved out all the surrounding grout) and then you can work on the individual tile in your hands for removing the piece of wall. Soaking in hot water sometimes helps soften the backing enough to get it off the tile.
This is about the only way to remove some large mirrors, too.... if you want to save the mirror.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
TheDoorGuy (02-19-2011)
Old 02-20-2011, 07:19 PM   #14
Rewards Points: 154
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 12:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 11:25 AM
