Removing A Wall, How To Support With A Vaulted Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 07:52 AM   #1
Removing a wall, how to support with a vaulted ceiling
I am removing a wall from my vaulted ceiling, currently the double plate runs from the far left wall (see yellow line) to the stud running to the ceiling (right side of picture) (3-2x4s)
The red is the wall I am removing, up to the green line. Leaving a wall (3 ft ish in length) next to the refrigerator.
The questions,
Am I able to just remove an cut, will this be sturdy enough?
If I cant, what options do I have to strengthen this wall.
Thanks in advance!
Removing a wall, how to support with a vaulted ceiling-20130331_201026_reduced.jpg
palabalo is offline   Reply With Quote
Old 04-12-2013, 08:14 AM   #2
Rewards Points: 502
If the post on the right is formed of 3-2x4s, it's possible it will be structural.
In that case, I would be inclined to have a look in the roof to see what, if anything, it might be supporting before removing it.
tony.g is offline   Reply With Quote
Old 04-12-2013, 08:19 AM   #3
The building inspector I had took a look at it an said it wasn't supporting. I have the go ahead to take out the post. Thanks for the info!
Any thoughts on whether or not the wall that remains would be sturdy?
Old 04-12-2013, 08:25 AM   #4
Roofmaster
Rewards Points: 2,210
Do you have scissor trusses? I guess so, but all I can do is guess.
Not enough data to make an informed comment.
Old 04-12-2013, 08:53 AM   #5
The post on the right is an off center post, and yes I am pretty sure I have scissor trusses.
I cant see any reason to put an off center supporting post, and my inspector agreed.
What info would help in determining if the little wall (green and to the left in the picture) would be stable?
Old 04-12-2013, 09:09 AM   #6
"You can do anything"-Mom
brockmiera's Avatar
If you have already figured out that you can remove that wall and not compromise the structural integrity of the roof then just remove it.
If the wall that you are leaving is not sturdy then lets talk about a solution. No sense hypothesizing about something that may or may not even happen. Good luck. Update with pictures.
brockmiera is offline   Reply With Quote
Old 04-12-2013, 11:26 AM   #7
Roofmaster
Yeah, what Brock Said. You said you have scissor trusses, so you can take out the red x wall, no problem.
The Following User Says Thank You to jagans For This Useful Post:
brockmiera (04-12-2013)
Old 04-12-2013, 12:06 PM   #8
AHH, SPANS!!!
Rewards Points: 1,166
where the door opening is, to the left of it (green line) make the wing wall go full height to the vaulted ceiling. if you demo part of that wall the wing wall floats at the top and needs to go to full ceiling height.
hand drive is offline   Reply With Quote
Old 04-12-2013, 01:50 PM   #9
GBrackins's Avatar
Rewards Points: 2,108
well that depends on if the wall you're removing is supporting the roof, if it is and you remove it the wall that remains may be damaged by the roof should it collapse. not sure how sturdy it would be then.
there is a reason why that column is at the end of the wall, it may be supporting a beam that is above the opening in that wall, with the beam going all the way to the exterior wall.
your inspector may have said it was not supporting, but how did the inspector determine that? Did he open up the ceiling, or did they just look at it .....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-12-2013, 01:55 PM   #10
GBrackins's Avatar
is the slope of the roof on the outside the same as the slope of the ceiling? if so then I doubt you have a scissor truss.
if the roof pitch is about twice that of the ceiling then YOU MAY have a scissor truss.
just don't want to see you have issues. Good luck!
Gary
Tags
partitioned wall , removal , vaulted ceiling
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Wall removal, ceiling joist issue. sc204 Building & Construction 21 07-15-2012 07:22 PM
want lowest profile load-bearing support beam (removing wall) rpk7309 Building & Construction 2 05-17-2012 07:48 AM
Removing wall latex paint from sheet rock ceiling dehlila123 Painting 3 10-18-2011 01:04 AM
Partition wall supporiting ceiling joists (recommendations for removal) afly007 Building & Construction 3 09-29-2011 10:57 AM
