Old 01-21-2012, 04:12 PM   #1
removing wall, can I patch laminate floor to connect 2 laminate floors?
Have 8" wide plank style pergo laminate (17 years old) in entry. It was professionally installed using glue. Have 15-1/2" wide high quality (expensive) laminate in adjacent room. Also professionally installed about 5 years ago, glueless. The two different floors are laid perpendicular to each other. The seams in one room run north/south and in the adjacent room run east/west.
The different laminate floors are in same colors and are joined with a molding strip of some sort in the door way where they connect. I want to remove a four foot section of wall next to the doorway and make a larger opening between the two rooms. There are sufficient left overs of either style of laminate and the molding strip. Can the hole in the floor (after removal of wall section) be patched?
Thanks in advance!
tworicks is offline   Reply With Quote
Old 01-21-2012, 06:06 PM   #2
The general answer is Probably
mae-ling is offline   Reply With Quote
Old 01-21-2012, 06:47 PM   #3
Framing Contractor
Thanks in advance!
Is the section if wall you are removing load bearing?
Joe Carola
Joe Carola is offline   Reply With Quote
Tags
laminate floor, patch, repair
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 12:58 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Removing a (block) wall - questions Genhawk21 Building & Construction 3 09-08-2007 07:26 PM
