Removing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 05:18 PM   #1
Removing wall
I have wall separating my kitchen and dining room, that I would like to remove. I'm pretty sure it's not load bearing, however the studs on my raised ceilings do sit on the top of it. In removing the wall, how big of a header do I have to install?
Cstahl86 is offline   Reply With Quote
Old 03-28-2011, 05:55 PM   #2
Civil Engineer
Rewards Points: 4,572
If the wall is not load bearing, you need only a small header. If the wall is load bearing, you need to size the header based on the span and the load above the header. In order to size the header, you need a carefully prepared, scaled diagram showing all of the load the header will need to pick up, which may require crawling into the attic to verify how much load is transmitted to the wall below.
Daniel Holzman is online now   Reply With Quote
Old 03-30-2011, 03:49 AM   #3
I am also pretty much agree with denial that size of header depends upon span and the bearing load. you can contact regarding this from a professional person.
kevin10387 is offline   Reply With Quote
Skim Coating wall After removing wallpaper stevenson66 Painting 6 11-08-2010 08:35 PM
removing wall, making arc, need to determine dimensions ilyaz Kitchen & Bath Remodeling 1 03-03-2010 07:30 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 12:14 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
